Displays information about OSPFv3 areas.
| area_identifier | Specifies an OSPFv3 area, a four-byte, dotted decimal number. |
| detail | Specifies to display the information in detailed format. |
N/A.
None.
The following command displays summary information about the OSPFv3 areas:
show ospfv3 area
The following is sample output:
AREA ID Type Summ Def Num Num Num SPF Num LSA Metric ABR ASBR Intf Runs LSAs Checksum 0.0.0.0 NORM ---- ------ 0 0 1 7 7 0x3155b 1.0.0.0 NORM ---- ------ 1 1 1 6 9 0x4793d 2.0.0.0 NORM ---- ------ 0 0 1 5 10 0x47174 3.0.0.0 NORM ---- ------ 1 0 1 3 12 0x420cf 5.0.0.0 NORM ---- ------ 1 0 1 4 10 0x3b5b1
The following command displays information about OSPFv3 area 1.0.0.0:
show ospfv3 area 1.0.0.0
Area Identifier : 1.0.0.0 Type : NORM Router ID : 20.0.0.1 Num of Interfaces : 1 Spf Runs : 6 Num ABRs : 1 Num ASBRs : 1 Num DC-Bit LSAs : 1 Num Indication LSAs : 1 Num of DoNotAge LSAs: 1 Num LSAs : 9 LSA Chksum : 0x4793d Num of Nbrs : 1 Num of Virtual Nbrs : 0 Interfaces: Interface Name Ospf State DR ID BDR ID to65 E BDR 0.0.0.65 20.0.0.1 accounts E DR 80.0.0.5 0.0.0.0 finance E BDR 90.0.0.7 66.0.0.4 engineering E ODR 192.168.0.1 165.0.0.3 Corporate E ODR 201.0.16.6 204.0.0.1 Inter-Area route Filter: ospfSummPolicy External route Filter: ospfExtPolicy Configured Address Ranges: Addr: fffe:408:1449::/48 Type: 3 Advt: Yes Addr: ffe0:930:2781::/40 Type: 7 Advt: No
This command is available on platforms with Base license, or higher, as described in the Switch Engine v33.1.1 Licensing Guide document.
